It is currently Sat Aug 02, 2025 10:33 pm
 Post subject: StewMac Heat Stick
PostPosted: Fri Dec 28, 2018 12:41 pm
Anyone tried it? I have a couple of neck resets coming up and it looks interesting.
 Post subject: Re: StewMac Heat Stick
PostPosted: Fri Dec 28, 2018 12:53 pm
Yes, I used it once and then got rid of it. It requires a hole that's .125 to be drilled in the fretboard.
Even when you use it you still have to add water to the joint to create steam, so it really doesn't accomplish much other the handle punching a big hole in the fingerboard.
YMMV
PostPosted: Fri Dec 28, 2018 1:47 pm
First name: Brad
Last Name: Combs
Interesting. I saw this demonstrated at Northwoods but I don't recall them adding water at that time. However, I just watched the SM video tutorial and sure enough water is being added.
I also don't remember the heat probe being that large, but maybe it had to be increased in size to fit soldering irons.
That's not a helpful response at all, Terence. Sorry. :(
PostPosted: Fri Dec 28, 2018 4:46 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
We used it in a Weller WESD-51 soldering station per directions on high...the heating element partially melted about 1/2 way through a neck removal. Likely works better with the soldering station that Stewmac sells. The WESD was repaired and passed to a student..the Hakko FX-951 is awesome. Back to a standard steamer setup.
- Beth Brower
PostPosted: Sat Dec 29, 2018 11:23 am
The cheapskate in me wonders if wrapping a length of bronze guitar string around a soldering iron and feeding the opposite end into a smaller hole would transfer enough heat to do the same thing? It would probably still require a little water but maybe less than a steamer uses. Soft copper wire might work better if you have it.
PostPosted: Sat Dec 29, 2018 2:05 pm
First name: Conor
Last Name: Searl
City: Duncan
State: British Columbia
Zip/Postal Code: V9L 2E5
Wouldn't the bronze wrap actually act as a heat sink dispersing it all on the way into the hole?
PostPosted: Sat Dec 29, 2018 3:10 pm
First name: Daniel
Last Name: Petrzelka
State: Washington
I've used the HeatStick on a few resets with great results. The access hole is my only consideration and in ebony boards it pretty easy to fill. With rosewood you'll want to find a close matching plug if it has thinner wire.
I do add water to the access hole, but there is no steam blowing around to damage finishes—everything moves along at a clean, causal pace.
https://www.instagram.com/p/Bh1U_6slJFF/
https://www.instagram.com/p/Bh0bOC8lzzU/
PostPosted: Sun Dec 30, 2018 5:51 pm
tried it once the 1/8 inch hole it too large I much prefer the steam method.
Users browsing this forum: eflottman and 40 guests
